Date/Time: Fri, 27 Dec 2024 18:28:20 +0000
Hide/Show Copied Drawings Only
View Count: 710
[2016-02-23 14:28:47] |
User765038 - Posts: 22 |
SC Support, I have a chart (#3) that has drawings copied from another chart (#1) that I would like to toggle on and off (whilst the drawings made originally on chart #3 continue to show). In other words, I wish to selectively hide/show, with a toggle, only those drawings copied from another chart. How can I achieve this? Thanks and regards, Rod |
[2016-02-23 18:24:20] |
This is not supported. You can only hide all of the drawings with Chart >> Hide Chart Drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
