Date/Time: Sat, 26 Sep 2026 11:23:52 +0000
Settings for Senkou Span A & B Study
View Count: 1303
| [2016-02-22 21:21:47] |
| User767730 - Posts: 3 |
When I apply the Senkou Span A&B onto a chart, the "colored" area of the Cloud covers the individual bars (and/or candles) so that you cannot see those bars or candles on the Chart. My question is: Is there a way to adjust the settings so that the Cloud becomes "faded" and hence you could see all bars (and/or candles) on the Chart whether or nor they are inside or outside of the Cloud? Please advise. Thanks, Joe Campion |
| [2016-02-23 03:38:28] |
We do not recommend using a transparent Draw Style but you could. Make sure the study is drawn underneath the price bars. Refer to: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
