Date/Time: Fri, 27 Dec 2024 18:26:38 +0000
Problem with scaling
View Count: 834
[2016-02-21 23:24:44]
User40278 - Posts: 3
Dear support,
after upgrading to windows 10, I have a problem with my sierra charts. While all my other programs (ninjatrader, browsers, office etc) show normal size of fonts and symbols, sierra is much smaller. I could at least adjust the fonts, they were shrinked to fontsize 3, while they were 9 before. But how can I adjust the rest like all the one click buttons and symbols. Everything seems to be shrinked after the upgrade. (see attachment)
Is there something like a zoom function or similar ? BTW I upgraded to the latest version 1371 on 4k monitors.I also installed a fresh copy in another folder in which the symbols also look very shrinked.
Thanks a lot.
imageshrinked buttons.jpg / V - Attached On 2016-02-21 23:21:30 UTC - Size: 15.17 KB - 309 views
[2016-02-22 17:34:36]
We can see that the Control Bar buttons that have a graphic are small.
Those used fixed size graphics and the size of them cannot be changed.
Either you can use your own graphics or change them to plaintext by using Control Bar Button Properties:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#ControlBarButtonProperties
