Date/Time: Sat, 26 Sep 2026 16:00:41 +0000
Proxy Server with authorisation
View Count: 1892
| [2016-02-21 22:00:18] |
| User888919 - Posts: 11 |
Hello, is it possible to connect SC via Proxy Server with authorisation? Thank u very much |
| [2016-02-21 23:22:59] |
A proxy is supported for when logging into Sierra Chart but it does not support authorization. For proxy server support, refer to: HTTP Communication Errors: 3 - HTTP Proxy Server However, there may be other proxy server programs which can be used which run on your computer which Sierra Chart can connect to which will provide the authorization support that you need. So you can use the proxy support in Sierra Chart to connect to that program and that program can then handle the authorization. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-22 07:12:53
| [2016-02-22 06:36:36] |
Thank you!
| [2016-02-22 07:15:42] |
Not sure this is exactly the kind of program that would be necessary, but here is something we came across with a quick Internet search which might be suitable: http://www.youngzsoft.net/ccproxy/proxy-server-softwares.htm Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-22 07:17:42
