Date/Time: Tue, 11 Mar 2025 07:04:48 +0000
FX Tick Chart Bar Period Question
View Count: 772
[2016-02-21 20:24:47] |
Pinger - Posts: 33 |
Hi My query relates solely to Forex. I'm using the "Bid and Ask Prices" study on a EURUSD-BIDASK chart to create a "tick" chart (i.e. a chart that is updated on each tick) but I'm confused about which Bar Period I should use. Should it be "Range per Bar" set to 1 tick, or "Number of Trades Per Bar" set to 1 tick? And what is the difference between the various "Range per Bar" types, e.g. Standard, True, etc? Thanks in advance. |
[2016-02-22 17:31:00] |
You need to use the symbol itself: EURUSD. In this case do not use a data recording suffix. Make sure Sierra Chart is set to a tick by tick data configuration: https://www.sierrachart.com/index.php?page=doc/doc_TickbyTickDataConfiguration.php Use this: "Number of Trades Per Bar" set to 1 tick
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
