Date/Time: Mon, 21 Apr 2025 04:41:22 +0000
Auto Trade Enabled
View Count: 1077
[2016-02-21 17:24:07] |
Litz - Posts: 131 |
When auto trading is enabled, does it enable auto trading in all chartbooks or just the current active open chartbook? IE will it enable auto trading in CL and ES and NQ?
[2016-02-21 20:21:30] |
It is enabled in all Chartbooks. We do have on our task list, to add the ability to enable auto trading for individual charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-21 20:35:21] |
Litz - Posts: 131 |
OK. Yes that would be a good improvement
[2022-12-27 04:29:24] |
User90125 - Posts: 715 |
Support, Since you've added Trade >> Auto Trading Enabled - Chart (and the corresponding Control Bar button), would it be possible to add Trade >> Trading Locked - Chart only (and a corresponding Control Bar button, as well) ? Use Case: Trading Locked shows [Lock] on the top left corner of a chart. However, this is a Global control. Having Trading Locked - Chart only (with the same [Lock] showing on the Chart would make it easier to view and control the Locked trading status of an individual chart. Do let me know as I'm willing to cover reasonable costs for this to be developed and implemented by staff. |
[2023-02-01 15:45:41] |
+1 for follow-up
