Date/Time: Fri, 27 Dec 2024 18:01:54 +0000
How to set these horizontal grid fixed at 10
View Count: 1359
[2016-02-21 12:47:04] |
bwasi - Posts: 34 |
http://www.sierrachart.com/image.php?l=1456058661231.png chart at right I have tried the graphic settings instruction but failed to draw it. tq support |
[2016-02-22 18:59:05] |
You need to use the Horizontal Grid Increment setting: https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
