Date/Time: Fri, 27 Dec 2024 18:02:00 +0000
Trade Management / Alerts
View Count: 812
[2016-02-21 05:56:51]
User78442 - Posts: 260
Hi, I use the Trade Management Study (TMS) to manage trailing stops - it works well.
I want to set a profit target (say on a long) at an upward sloping line (as time goes on the target increases) - Is there an easy way to do this using the TMS?
2nd question - Is there anyway of linking orders to alert conditions?
Regards, James
[2016-02-21 08:23:40]
1. You need to create the study and have the Trade Management by Study reference it.
2. Not directly. You need to use ACSIL for this.
[2016-02-21 16:19:33]
Is there a study for sloping lines/segments?
[2016-02-21 20:28:50]
You have to create one to do what you require.
[2016-02-22 04:50:01]
Does this require ACSIL programming? If so can you recommend any programmers?
[2016-02-22 18:11:02]
Yes. Refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.html
