Date/Time: Mon, 14 Sep 2026 20:36:48 +0000
[User Discussion] - Volume spike coding
View Count: 3688
| [2013-06-30 21:16:21] |
| user85017 - Posts: 37 |
Hello, this is the indicator code called "High Volume Spike Reversal" for tradestation platform, do you think it's possible to have it for sierra Vars: iVolume(0); If bartype < 2 then iVolume = Ticks else IVolume = volume; //HIGH VOLUME SPIKE LONG SIGNAL Condition1=Low<=Low[1] AND Low<=Low[2] AND Close>=Close[1] AND Close>=Open AND (Close-Open)<(High-Low) AND iVolume[1]>iVolume[2] AND iVolume[1]>iVolume[3] AND iVolume[1]>iVolume[4] AND iVolume[1]>iVolume[5] AND iVolume[1]>iVolume[6]; Condition2=Low>=Low[1] AND Low<=Low[2] AND Close>=Close[1] AND Close>=Open AND (Close-Open)<(High-Low) AND iVolume[1]>iVolume[2] AND iVolume[1]>iVolume[3] AND iVolume[1]>iVolume[4] AND iVolume[1]>iVolume[5] AND iVolume[1]>iVolume[6]; //HIGH VOLUME SPIKE SHORT SIGNAL Condition3=High>=High[1] AND High>=High[2] AND Close<=Close[1] AND Close<=Open AND (Open-Close)<(High-Low) AND iVolume[1]>iVolume[2] AND iVolume[1]>iVolume[3] AND iVolume[1]>iVolume[4] AND iVolume[1]>iVolume[5] AND iVolume[1]>iVolume[6]; Condition4=High<=High[1] AND High>=High[2] AND Close<=Close[1] AND Close<=Open AND (Open-Close)<(High-Low) AND iVolume[1]>iVolume[2] AND iVolume[1]>iVolume[3] AND iVolume[1]>iVolume[4] AND iVolume[1]>iVolume[5] AND iVolume[1]>iVolume[6]; IF Condition1 OR Condition2 then Plot1(1,"Spike") else If Condition3 or Condition4 then Plot1(-1,"Spike") else Plot1(0,"Spike"); Date Time Of Last Edit: 2013-06-30 21:16:39
| [2013-06-30 23:35:04] |
| M5amhan - Posts: 468 |
=OR(AND(L<=L[-1],L<=L[-2],C>=C[-1],C>=C[-1],C>=O,(C-O)<(H-L),V[-1]>V[-2],V[-1]>V[-3],V[-1]>V[-4],V[-1]>V[-5],V[-1]>V[-6]),AND(L>=L[-1],L<=L[-2],C>=C[-1],C>=O,(C-O)<(H-L),V[-1]>V[-2],V[-1]>V[-3],V[-1]>V[-4],V[-1]>V[-5],V[-1]>V[-6])) this is your "high volume spike long signal" condition 1 & 2. i dont know what "If bartype < 2 then iVolume = Ticks else IVolume = volume;" is supposed to mean. follow that frame work for your short signals code and use 2 "color background based on alert condition" studies and put long signal formula in one and short signal formula in another |
| [2013-07-01 05:36:18] |
Hello thanks for your code but in fact, i would like this code as a studie (see pictures) i find the same scipt for ninja so i don't know if it's possible for sierra thanks ninja script : protected override void OnBarUpdate() { // Use this method for calculating your indicator values. Assign a value to each // plot below by replacing 'Close[0]' with your own formula. //HIGH VOLUME SPIKE LONG SIGNAL if (CurrentBar > period) { if ( (Low[0]<=Low[1]) && (Low[0]<=Low[2]) && (Close[0]>=Close[1]) && (Close[0]>=Open[0]) && (Close[0]-Open[0])<(High[0]-Low[0]) && //(Volume[1]>Volume[2]) && (Volume[1]>Volume[3]) && (Volume[1]>Volume[4]) && (Volume[1]>Volume[5]) && (Volume[1]>Volume[6]) ) (Volume[1]>MAX(Volume,period)[2]) ) { BackColor = Color.Green; //Spike.Set(1); } if ( (Low[0]>=Low[1]) && (Low[0]<=Low[2]) && (Close[0]>=Close[1]) && (Close[0]>=Open[0]) && ((Close[0]-Open[0])<(High[0]-Low[0])) && //(Volume[1]>Volume[2]) && (Volume[1]>Volume[3]) && (Volume[1]>Volume[4]) && (Volume[1]>Volume[5]) && (Volume[1]>Volume[6]) ) (Volume[1]>MAX(Volume,period)[2]) ) { BackColor = Color.Lime; //Spike.Set(1); } //HIGH VOLUME SPIKE SHORT SIGNAL if( (High[0]>=High[1]) && (High[0]>=High[2]) && (Close[0]<=Close[1]) && (Close[0]<=Open[0]) && ((Open[0]-Close[0])<(High[0]-Low[0])) && //(Volume[1]>Volume[2]) && (Volume[1]>Volume[3]) && (Volume[1]>Volume[4]) && (Volume[1]>Volume[5]) && (Volume[1]>Volume[6]) ) (Volume[1]>MAX(Volume,period)[2]) ) { BackColor = Color.Crimson; //Spike.Set(-1); } if( (High[0]<=High[1]) && (High[0]>=High[2]) && (Close[0]<=Close[1]) && (Close[0]<=Open[0]) && ((Open[0]-Close[0])<(High[0]-Low[0])) && //(Volume[1]>Volume[2]) && (Volume[1]>Volume[3]) && (Volume[1]>Volume[4]) && (Volume[1]>Volume[5]) && (Volume[1]>Volume[6]) ) (Volume[1]>MAX(Volume,period)[2]) ) { BackColor = Color.Red; //Spike.Set(-1); } } } |
| [2013-07-01 19:16:30] |
| vegasfoster - Posts: 444 |
I can do it if you do the legwork, take the nt code and put sc. in front of all the high, low, close, and volume, and put sc.Index- before each index reference, for example change High[1] to sc.High[sc.Index-1], then repost the code. Unless someone less lazy than me wants to do it. :)
Date Time Of Last Edit: 2013-07-01 19:17:05
| [2013-07-02 05:12:27] |
it's ok now thanks anyway
