Date/Time: Fri, 27 Dec 2024 17:08:21 +0000
Recommended Brokers
View Count: 941
[2016-02-18 21:23:11] |
Pjimmy - Posts: 14 |
Hi, I have read through what I could on your website and understand that Interactive Brokers is possibly not your preferred choice of broker due to the headaches caused by their software. As I am yet to open an account with a broker could you give a subjective opinion on Sierra's choice for stability and price in the futures market? P.S. My reasoning for leaning towards IB was the transactional costs and fast fills (not including data feeds which I would get through Sierra). Regards Paul |
[2016-02-19 00:34:13] |
Kiwi - Posts: 375 |
User Opinion: unless you're in a market where one of the other reputable brokers offers a stunningly good deal then IB is a good solution. The SC team, as much as they dislike IB do a better job than anyone else at providing a perfect platform for trading with IB !!! A user of both for over a decade (since SC v30s) :-) |
[2016-02-19 00:51:08] |
Hi Kiwi, Thanks for your advice. If you're in NZ would I be able to contact you directly? I would appreciate any advice as a fellow kiwi trying to set up for trading with international providers. My email is: pjimmyinahouse@gmail.com Cheers Paul |
[2016-02-19 04:31:08] |
If you use the Sierra Chart Exchange Data Feed with Interactive Brokers you should be all right.
