Date/Time: Fri, 28 Feb 2025 01:52:00 +0000
Spreadsheets Insert Row or Insert Column issue
View Count: 679
[2016-02-18 16:11:46]
Sawtooth - Posts: 4177
If a spreadsheet sheet is added with Spreadsheet >> Add Sheet, references to/from a chart's sheet move in the opposite direction of the added row or column.
See attached test spreadsheet.
To replicate when inserting a column:
-On the Control sheet, highlight column C, and Insert Column.
-Go to Sheet2, and focus cell J26. It shows =Control!B3 when it should be =Control!D3
-To undo, on the Control sheet, highlight column C, and Delete Column.
To replicate when inserting a row:
-On the Control sheet, highlight row 3, and Insert Row.
-Go to Sheet1, and focus cell J26. It shows =Control!B2 when it should be =Control!B4
Date Time Of Last Edit: 2016-12-05 03:14:58
attachmentInsert test.scss - Attached On 2016-02-18 16:10:07 UTC - Size: 68.79 KB - 346 views
[2016-02-18 17:21:01]
We will be looking into this.
