Date/Time: Sun, 27 Sep 2026 12:22:25 +0000
volume at price threshod alert
View Count: 989
| [2016-02-18 15:13:54] |
| MAX DELTA - Posts: 27 |
Up until recently I have had no problem with the Vol.at price threshold alert in studies. I did actually have 2 studies on for the dax on the no's bars. one was set to 70 & the other alerts over 100. I unfortunately for no obvious reason was getting multiple dings, (alerts). I now just have 1 threshold limit alert set to 70. It will however go off sometimes even when we don't have a 70 on the no's bars study printed & still occasional multy dings on a price threshold over 70? which I never had before? I have removed the study & then put the study back on but it seems to be the same. Please advice as I don't seem to be able to resolve this. Kind regards, Karl. |
| [2016-02-18 17:12:39] |
Are the Alerts from this study? You can tell from the Window >> Alert Manager >> Alerts Log. What are the exact Input settings you are using for this study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
