Date/Time: Fri, 27 Dec 2024 17:20:31 +0000
change menu item using ACSIL
View Count: 902
[2016-02-18 13:51:00]
wwwingman - Posts: 185
Hi
I use sc.AddACSChartShortcutMenuItem for creating new menu items.
I would like to change the name of the menu at some situations.
Is this possible ? Do I have to remove it and creat a new one ?
( I don't think there is a change name function in the documentation ).
Thank-you,
-- W
[2016-02-18 14:24:36]
ejtrader - Posts: 688
+1 - Was looking for the same in the past - but this option was not available. Would be a nice addition to have an option to "rename the menu item" based on the context.
Date Time Of Last Edit: 2016-02-18 14:25:16
[2016-02-18 17:05:30]
We will see if it is not difficult to add a function to rename a menu item added through ACSIL.
[2016-02-18 18:58:33]
Al SC Developer - Posts: 434
In the next version we have added a new function
bool ChangeACSChartShortcutMenuItemText(int ChartNumber, int MenuIdentifier, const char* NewMenuText)
Date Time Of Last Edit: 2016-02-18 18:58:51
