Date/Time: Fri, 27 Dec 2024 18:34:24 +0000
How to enable Sell and Buy orders in TradeDOM?
View Count: 1521
[2016-02-18 11:27:43] |
Kris - Posts: 3 |
What the title says... I've attached two images to illustrate. The first one is what I'm looking for. The second one is what I've got. 1) http://imgur.com/CVFyRo5 2) http://imgur.com/WFTVMac Any help is appreciated. Thanks. |
[2016-02-18 17:46:55] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns However, the particular symbol you are using only provides one level of depth. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-18 22:14:48] |
Kris - Posts: 3 |
Thanks for the reply. Is it possible to get the DOM for EURUSD with more than one level of depth? I can't seem to display any orders in the Buy Sell columns.
[2016-02-18 23:37:52] |
Only for futures. Or if you use the supported LMAX trading service. You should see 1 and 1 in the Buy and Sell columns respectively if you have added columns which have Bid Size and Ask Size.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-18 23:39:02
[2016-02-22 12:34:48] |
Kris - Posts: 3 |
I've managed to get DOM working and it's great. However I'd like to customize it to my liking. I'm looking at EURUSD and DOM shows me 10th of a pip increments, e.g. 1.10250, 1.10251, 1.10252, 1.10253 etc. and Bid Size and Ask Size for every increment. I the Chart Settings window, I've changed the scale and now I'm looking at DOM with 1 pip increments, e.g. 1.1025, 1.1026, 1.1027 etc. However, The Bid and Ask Size is still showing for 1oth of a pip and it all looks messy. I've attached a screenshot to illustrate. Is it possible to combine all those Bid and Ask Sizes and show a sum for each pip? http://i.imgur.com/4ItILkT.png |
[2016-02-22 17:40:55] |
No this is definitely not supported. To post image of a chart only use the method described here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-22 18:26:07] |
User218309 - Posts: 1 |
Hi, I have the same problem, but with chart DOM. I have tried setting up columns according to the manual but it does not work. Please find attached my screen with the problem. It did not work right from when I installed Sierra. Is that normal? Thanks
[2016-02-22 18:55:27] |
Regarding post #7, refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
