Date/Time: Thu, 26 Dec 2024 11:51:01 +0000
Exporting chart definitions
View Count: 791
[2016-02-18 06:35:12] |
User815073 - Posts: 14 |
Hi, I need to re format my hard drive but before doing so need to save all the chart definitions to a flash drive so I can import them and have all the charts as I had them. I imported a chart a while back but can't remember how I did it or what the process was called. Thanks, James |
[2016-02-18 07:31:01] |
Make a copy of the entire Sierra Chart folder. To save space you can leave out the files with a scid file extension. And then you can restore it by following the instructions in help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-18 07:31:17
