Date/Time: Fri, 27 Dec 2024 17:06:20 +0000
Time Line Study Text Size
View Count: 639
[2016-02-18 05:29:58] |
User902167 - Posts: 31 |
How can i change the custom text size of the study Time Line ? The text is so small i can't read it, i have tried all the text settings in Global Settings>Graphics Settings>Fonts and nothing there changes it.
[2016-02-18 18:31:55] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s181 Refer to the Custom Label Text input description. It explains how to do this. The page has been modified so you may need to reload it for the latest content. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
