Date/Time: Fri, 27 Dec 2024 18:34:08 +0000
Import Trade Activity is not working
View Count: 762
[2016-02-17 22:39:57] |
User922653 - Posts: 2 |
I'm exporting my sim trades into a file. Then clearing all sim trades via "Clear Trade Simulation Orders&Data". Then importing the trades back from the file and there's absolutely nothing. Tries a few times, restarted Sierra and tried again but no luck. What could be wrong? |
[2016-02-17 22:53:53] |
I'm using build 1366
[2016-02-18 02:46:37] |
We will check on this.
[2016-02-18 04:02:45] |
Simulated order fills cannot be currently imported. However, we are adding that capability. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-20 06:06:55] |
User393975 - Posts: 5 |
Thanks, I'm looking forward!
