Date/Time: Thu, 26 Dec 2024 11:59:24 +0000
Entry/Exit times for trades are incorrect on Log
View Count: 682
[2016-02-17 22:27:10] |
katek - Posts: 28 |
Trade Log entry/exit times do match entry/exit times with IB or the prices shown on bars (please see attached image). There is a 5 seconds difference. Is there anything that can be done to correct this? Thank you. |
Capture2.PNG / V - Attached On 2016-02-17 22:26:12 UTC - Size: 34.8 KB - 250 views Attachment Deleted. |
[2016-02-17 23:16:27] |
This is an indication your computer's clock is not accurate. Refer to help topic 38: http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-18 05:06:29] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#MisalignedOrderFillMarkers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
