Date/Time: Fri, 27 Dec 2024 01:48:35 +0000
[User Discussion] - Requesting help in comparing exported data for ETH to RTH sesssions
View Count: 754
[2016-02-17 19:47:47] |
Yoda - Posts: 106 |
I would like to compare exported data from the Regular Trading Hours (RTH) session (9:30:00 - 16:14:59 EST) to the Evening Trading Hours (ETH) session (16:30:00 - 09:29:59 EST) that end on the same day. So for example, I would like to compare the following two sessions (the time is the ending time of the sessions): 2016-02-16 09:29:59 Op Hi Low Last vs. 2016-02-16 16:14:59 Op Hi Low Last To export the data I've used the Edit -> Export Bar Data to Text File and also the Spreadsheet Study. However, I've run into two issues: 1. SC is exporting the data showing the Starting time which means that the dates for RTH & ETH don't match, and 2. I tried solving the 1st issue by just moving the rows up by one. However, I'm still left with an extra ETH from Friday's shorten ETH which doesn't match to a RTH session because I use Sunday's ETH to compare to Monday's RTH. Is there a way to export the data that shows the end time of the session? This should resolve my 1st issue. The second issue I'm not sure how to resolve. Any ideas or suggestions on how I can resolve the above issues? Thank you, Richard |
[2016-03-07 20:48:50] |
User91026 - Posts: 16 |
This is a brilliant observation. this creates a little bit of a hindrance in running accurate stats on the product. I second this post and request SC to please looking into this.
[2016-03-07 20:55:26] |
This is not within the scope of our support and it is marked as a User Discussion.
[2016-03-07 22:42:44] |
User348701 - Posts: 23 |
Mark me down as also being interested in a response on this
[2016-03-07 22:44:15] |
User17477 - Posts: 65 |
Will you please consider helping with this SC support?
