Date/Time: Thu, 26 Dec 2024 12:12:37 +0000
SC DATA FEED SERVICE - GENERAL/SPECIFIC INFOS REQUEST
View Count: 761
[2016-02-17 18:27:50] |
FerroTrader - Posts: 70 |
Hello, I would like, if possible, some infos about your data feeding service: 1. how much is it per month considering that I need CMe/EUREX data feeding (both L1 and L2 data ) ? 2. do you provide CBOT/NYMEX/COMEX both L1 and L2 data ? 3. where are your CME servers ? is there an IP address to ping, please ? I hope they are in Chicago. 4. honestly, is there any possible speed increase in using you data feeding due to the fact that I think it could be 100% integrated into the platform ? 5. could I connect SC to Interactive Brokers TWS trading platform without opening two SC instances ? Could I still conncet SC to Trade4Less as a broker too ? I am looking forward to hearing from you. Thank you very much, CP |
[2016-02-17 18:45:05] |
1. Pricing can be found here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing 2. Yes. 3. Chicago. Yes use DS6.SierraCharts.com 4. A little but this would be in the millisecond range. But not because of how the data feed is integrated. Only because it is a low latency data feed. 5. Yes. Refer to: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
