Date/Time: Wed, 30 Oct 2024 22:55:53 +0000
[User Discussion] - Code
View Count: 1489
[2013-06-30 12:47:43] |
narcese - Posts: 58 |
What is the formula for tick price to be greater than or less than? What is formula for price is greater than or less than? Thanks |
[2013-06-30 18:37:06] |
Where in Sierra Chart do you want to use this formula?
[2013-07-01 16:08:47] |
On tick and main price chart
