Date/Time: Tue, 29 Sep 2026 04:08:57 +0000
Daily P&L in TW: ignore quantity is ignored
View Count: 1218
| [2016-02-17 12:48:33] |
| phaedonk - Posts: 352 |
I need to see only the net P&L points, per contract. I choose Points, Ignore quantity, but that only works for the position line. The Trade Window ignores the setting and keeps diplaying sum of points. Can you change this so we have the option?
Date Time Of Last Edit: 2016-02-17 12:51:07
| [2016-02-17 19:32:05] |
No. The documentation explains this is not supported for anything other than the Open Profit/Loss. Also we are not accepting new suggestions at this time. We already have a huge massive amount of work. It is pointless to be requesting new features. Refer to the posting at the top of the Support Board about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-17 19:32:34
