Date/Time: Sat, 12 Sep 2026 15:14:05 +0000
Saving sc.StorageBlock Data
View Count: 1478
| [2016-02-17 04:50:58] |
| William O - Posts: 16 |
I would like to save the StorageBlock data to disk immediately after storing a new value. As I understand it, the StorageBlock data is written to disk when the chartbook is saved. The only solution I found is to set the chartbook to periodically save, which would then also save the StorageBlock data. Is there a way to manually save the chartbook instead of waiting for the periodic save method? It would be nice to have sc.SaveChartbook() or sc.SaveStorageBlock(). Thanks |
| [2016-02-17 04:52:24] |
We can provide a Save Chartbook function but that is the only way to save the storage block. The entire Chartbook is written at once. There is no other possibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-17 04:58:39] |
In that case, having the SaveChartbook is something I'd like to see.
| [2016-02-17 10:24:07] |
| Marmany - Posts: 319 |
+1
