Date/Time: Sat, 28 Dec 2024 09:36:19 +0000
1369 error
View Count: 740
[2016-02-17 02:37:16] |
User20450 - Posts: 330 |
since 1369 download i have been getting this error message and i cant use this tool , any ideas
2016-02-16_21-36.jpg / V - Attached On 2016-02-17 02:37:12 UTC - Size: 12.97 KB - 229 views |
[2016-02-17 02:40:59] |
No idea. The developer needs to look into this and if there is some question they have for us, they need to ask. Hopefully, they will check into it soon. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
