Date/Time: Thu, 26 Dec 2024 12:21:27 +0000
PROGRAM IN ACSIL
View Count: 725
[2016-02-16 20:13:06] |
User82615 - Posts: 106 |
HELLO I WOULD LIKE TO ASK YOU A QUESTION : I WORK WITH BAR CHARTS AND AN ACSIL TRADING SYSTEM THAT TAKE ACTION AT THE CLOSE OF EACH BAR. MY QUESTION IS IF IT IS POSIBLE IN SIERRA CHARTS IF I SEND A LIMIT ORDER AT A PRICE AND IT DOESN'T GET FILLED AND THEN THE PRICE MOVES SOME TICKS AWAY FROM WHERE THE LIMIT ORDER WAS SENT , BUT THE BAR STILL HAS NOT CLOSED ,THEN I WOULD LIKE THE TRADING SYSTEM TO CANCEL THAT ORDER AUTOMATICALLY ,SO WOULD IT BE POSSIBLE TO PROGRAM IN ACSIL TO CANCEL THIS ORDER BEFORE THE BAR HAS CLOSED,? . SO IT WOULD BE TO CLOSE AN OPEN ORDER BUT IN INTRA - BAR, IT WOULD SEND THE LIMIT ORDER AT THE LAST OF THE PREVOUS BAR AND IT WOULD CANCEL THE ORDER AT A DETERMINED PRICE LEVEL BUT BEFORE THE BAR (WHERE THE ORDER WAS SENT) HAS CLOSED. THE TRADING SYSTEM WOULD TRACK THE MARKET AND THEN WHEN IT GET TO A PRICE LEVEL THE ORDER IS CANCELLED AUTOMATICALLY, EVEN IF THE BAR STILL HAS NOT CLOSED.IS IT POSSIBLE TO PROGRAM THAT IN ACSIL? IF SO COULD YOU GIVE ME PLEASE A HINT OF HOW TO DO THIS? THANK YOU VERY MUCH IN ADVANCE. |
[2016-02-18 04:48:18] |
You need to manually cancel the order at the appropriate time using the function documented here: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#CancelFlattenFunctions This is all the information we can provide. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
