Date/Time: Sat, 28 Dec 2024 10:07:08 +0000
Russell 2000 Future dead
View Count: 1041
[2016-02-16 19:32:56] |
Cavalry3162 - Posts: 523 |
Hello Support, russell once again dead.. |
[2016-02-16 19:34:31] |
seems to work again, but 4 minutes of history missing
2016-02-16_14-33-35.png / V - Attached On 2016-02-16 19:33:56 UTC - Size: 21.87 KB - 290 views |
[2016-02-16 19:50:33] |
We are checking on this and see what Barchart says about this. We will patch the missing data at the end of the day.
[2016-02-17 03:32:42] |
From Barchart: We are aware, and moving ICE onto our OpenFeed is a top priority for us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
