Date/Time: Sat, 28 Dec 2024 10:05:59 +0000
Live and Sim Trading at Same Time
View Count: 1014
[2016-02-16 15:00:28] |
User937866 - Posts: 12 |
Is it possible to have 2 charts set for live trading and a 3rd set to simulated trading to practice a new security?
[2016-02-16 17:34:36] |
We see you are using Rithmic. What you need to do is install another copy of Sierra Chart and set it to use Trade Simulation Mode. Refer to the instructions here: Using Multiple Data and Trading Services at the Same Time Or, if you want to wait about a month, there will be new version which will support easily starting a new instance which can be configured differently. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
