Date/Time: Sat, 28 Dec 2024 09:37:01 +0000
aeroplane noise
View Count: 725
[2016-02-16 12:02:40] |
User389908 - Posts: 1 |
Whenever I start sierra chart in sim or live mode I hear a sound like that of an old aeroplane. This has just started to happen -I have been using sierra chart for around 16 months through Infinity Futures.Do you have any suggestions?
[2016-02-16 17:14:13] |
This is coming from some event playing an Alert Sound Refer to: https://www.sierrachart.com/index.php?page=doc/doc_AlertsManager.html#GloballyMuteAlertSounds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
