Date/Time: Sat, 28 Dec 2024 10:07:12 +0000
ICHIMUKU MA CROSSOVER
View Count: 802
[2016-02-16 02:00:26] |
madra - Posts: 109 |
HELLO I am attempting to set an alert when ID4 chikou SPAN (Ma 26) crosses senkou span B ID6 (MA 52) =CROSSOVER(ID4.SG1, ID6.SG1) I GET FORMULA ERROR IN ALERT LOG. wHAT HAVE i GOT WRONG? Charlie |
[2016-02-16 03:12:17] |
Could you please provide us the exact line in the Alerts Log containing the error message. You can copy by selecting it and selecting Edit >> Copy Selection. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-16 04:45:28] |
Alert Formula Error - Chart: AAPL Daily #2 | Study: Senkou Span B | Error: The formula has no value. | Formula: =CROSSOVER(SG4, SG6) | No alert sound/email Alert Formula Error - Chart: AAPL Daily #2 | Study: Senkou Span B | Error: The formula has no value. | Formula: =CROSSOVER(SG4, SG6) | No alert sound/email |
[2016-02-16 07:39:11] |
According to this, on the Study: Senkou Span B on the Chart: AAPL Daily #2, the formula you actually have entered is =CROSSOVER(SG4, SG6) and not =CROSSOVER(ID4.SG1, ID6.SG1). Also, update Sierra Chart to the current version with Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-16 15:39:39] |
Hello, There is something wrong here. I have entered the original formula a few times with the same result =CROSSOVER(ID4.SG1, ID6.SG1) LOG READING =CROSSOVER(SG4, SG6). I tried =crossover(ID7.SG1, ID3.SG1) Log still reads =CROSSOVER(SG4, SG6) |
[2016-02-16 17:36:31] |
What is the chart number you are entering the formula on? You will see this at the top line of the chart after the #.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-16 17:37:07
[2016-02-16 17:54:41] |
#2 This may be an issue. I am using AWL for a number of stocks. I click on symbol using the same chart. I noted when I changed the alert from ID7.SG1, ID6.SG1 THE FORMULA WAS TRUE FOR GLD BUT NOT AAPL Now when i enter the formula nothing appears in the log |
[2016-02-16 18:56:13] |
If you are not getting any message in the Alerts Log about there being an error with the formula, then the error no longer exists.
[2016-02-16 19:06:43] |
THANK YOU, WE'LL SEE HOW IT GOES
