Date/Time: Sat, 28 Dec 2024 09:43:30 +0000
IB Data Trades Displayed
View Count: 756
[2016-02-16 01:59:27] |
User623839 - Posts: 108 |
I use TWS to enter trades but Sierra w/IB data feed for charting. How can I get the trades I took to show on my Sierra Charts (triangle entry/exits) if I'm not entering them through Sierra?
Date Time Of Last Edit: 2016-02-16 01:59:50
[2016-02-16 03:14:20] |
Refer to step 15 here: Interactive Brokers Trading Service: Setup Instructions You need to set Sierra Chart be able to receive all orders from TWS. Also refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#DisplayingOrderFills Unless Sierra Chart is running when the order fills occur, this is not going to work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-16 03:14:43
