Date/Time: Thu, 26 Dec 2024 12:06:20 +0000
Charts stop loading after opening 28 chart book
View Count: 754
[2016-02-15 21:27:15]
User99567 - Posts: 9
Dear support,
when i open more than 28 chart books that stop loading. The memory of the SierraChart.exe is about 2,5GB.
Do you know why this happens?
Thanks in advance,
With kind regards,
Maikel
[2016-02-15 22:01:21]
Are there any error messages in the Window >> Message Log?
[2016-02-16 21:07:14]
yes i have some error code
2100 and 2103 and 2104 are the numbers i see with error code
[2016-02-16 21:09:59]
i think the problem is IB, but how can i solve this. i already shut down days to load to min size
[2016-02-17 04:59:56]
that stop loading.
What do you mean by this?
What are the exchanges the symbols trade on in your 28 Chartbooks?
[2016-02-17 07:15:01]
the symbols are most from the forex market( aud.cad-cash-idealpro and some futures , oil/gold/S&p/nasdaq/estx50/bund/dax.
the meaning of above is , i cut down yhe days to load, so siƫrra is using now 2,7 gb, and the max is 3,9 gb to use.
and i have also an other problem now, suddenly all my charts and chartsbooks, you see at the bottom.......in green historical download complete..... all the time it go away, but not now
[2016-02-18 02:38:19]
There are three things you can do.
Use another instance of Sierra Chart to distribute processing load. This is documented here:
Using Multiple Data and Trading Services at the Same Time
This is going to be much easier in a new version coming out in about three or four weeks from now.
Use the Sierra Chart Forex data feed symbols which are listed in File >> Find Symbol >> Forex.
For futures, use the Sierra Chart Exchange Data Feed:
By using the Sierra Chart data feeds, data access will be much faster and reliable.
Also refer to:
Interactive Brokers Trading Service: Slow Historical Data Downloading
Date Time Of Last Edit: 2016-02-18 02:40:21
