Date/Time: Sat, 28 Dec 2024 10:01:45 +0000
GET THE PRICE OF THE CLOSE OF THE BAR
View Count: 688
[2016-02-15 19:38:38]
User82615 - Posts: 106
HELLO I WOULD LIKE TO ASK YOU WHAT FUNCTION IS NECESSARY TO USE WHEN PROGRAMMING IN ACSIL A TRADING SYSTEM IF I WANT TO GET THE PRICE DATA OF THE CLOSE OF THE BAR , TO LATER CANCELL AN ORDER BASED ON THIS PRICE OF THE CLOSE OF THE BAR.
FOR EXAMPLE I SENT A LIMIT ORDER AT THE CLOSE OF THE BAR , BUT IT DID NOT GET FILLED , THEN THE PRICE MOVED AWAY 2 TICKS FROM THE CLOSE OF THE BAR , THEN I WOULD LIKE TO CANCEL THAT LIMIT ORDER.
SO IN ACSIL I WOULD PROGRAMME IT THESE WAY : WHEN THE PRICE HAS MOVED 2 TICKS FROM THE CLOSE OF THE BAR , THEN CANCELL THE LIMIT ORDER.?
COULD YOU HELP ME HOW TO DO THESE PLEASE?
THANK YOU IN ADVANCE
[2016-02-15 23:29:35]
You need to use the arrays which are documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scBaseDataIn
