Date/Time: Mon, 12 Oct 2026 13:37:23 +0000
Need some index on Sierra
View Count: 1259
| [2016-02-15 19:28:49] |
| User214223 - Posts: 2 |
Hi, I need some european index from IB feed, like TICK-IBIS and TICK-LSE on Sierra. I don't know how to do. |
| [2016-02-15 19:30:17] |
Refer to this section here for the proper symbol format: Interactive Brokers Symbols: Index Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-17 09:39:55] |
For exemple, I do TICK-IND-IBIS or TICK-IBIS-IND-IBIS for Tick-IBIS, TICK-IND-LSE or TICK-LSE-IND-LSE for Tick-LSE, but it don't work.
| [2016-02-17 09:52:18] |
OK then they do not work. This is one of the consequences of using Interactive Brokers.. It is a very complex system and it also does not always work properly. You will need to contact Interactive Brokers about this. It is their responsibility to help you and provide proper symbology which they do not. It is a complete joke as to how complex the IB symbology is when it does not even have to be that way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-17 09:53:08
| [2016-02-17 15:40:51] |
Here is the procedure to contact Interactive Brokers about this: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#ContactingIBForSymbolSpecifications Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
