Date/Time: Mon, 28 Sep 2026 21:26:25 +0000
ES data
View Count: 908
| [2016-02-15 15:44:20] |
| User750825 - Posts: 2 |
I have noticed on the ES 240 and 60 minute charts which I am using that data is missing. Data from 3/14/15 to 9/10/15 is missing on both charts. I also use the daily, weekly and monthly charts and that data is on those charts. I have data settings on all those charts set to "continuous futures contract - Volume Based Rollover." I have reloaded the 60 and 240 minute charts a few times and the data does not show up. I have contacted Infinity, who the data is fed thru, and also Trade Guider, whose software use, and they both had no idea what would cause this issue. It suggested I go on here and see if anyone has might know how to resolve this. Thanks. Gar Date Time Of Last Edit: 2016-02-15 16:05:24
| [2016-02-15 19:13:12] |
Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
