Date/Time: Fri, 02 Oct 2026 18:03:31 +0000
Simulated Trading with Sierra Chart Historical Data Service
View Count: 2093
| [2016-02-15 14:39:26] |
| NeoTrader86 - Posts: 32 |
Hello. I want to sign up for the 18 months of package 3 of Sierra Chart, so that I can do Simulated Trading with QQQ and/or SPY. I already read that the Sierra Chart Historical Data Service doesn´t provide Streaming Real Time or Delayed Streaming Data Feed. I use Volume Charts, which I know requires tick by tick Data and this Data is included up to 90 days for US Stocks in the Sierra Chart Historical Data Service. Since Simulated Trading is also included in the package, my question is: Will I be able to Simulate Trades in a way that when I enter a position, I´m able to see it developing approximately as if it was real, just with the delay of 10 to 15 minutes? |
| [2016-02-15 18:56:07] |
Yes this will be the case if you Replay the chart: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-18 15:08:42] |
Thank you... I am using the Replay mode and everything works perfectly... As always every text in the Website explains everything very clearly... I´m trying to find a way to place the Trade Windows on the right side of my chart, instead of the Left as it is apparently by default when I tell it to attatch it to my chart... I already looked up the way to customize the Trade Window and Trade DOM, but haven´t found this specific option... Is there a way to do this? |
| [2016-02-18 17:45:04] |
Refer to the documentation here for this: Basic Trading and the Trade Window: Attaching Trade Window to Right Side of Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
