Date/Time: Sat, 28 Dec 2024 10:13:31 +0000
LIMIT ORDERS
View Count: 729
[2016-02-15 11:26:21] |
User82615 - Posts: 106 |
HELLO I HAVE A QUIESTION ABOUT LIMI ORDERS: WHAT HAPPENS WITH THE LIMIT ORDERS WHEN THEY ARE NOT FILLED TOTALLY OR NOT FILLED AT ALLL ? ARE THEY CANCELLED AUTOMATICALLY (THE REST OF THE ORDER THAT HAS NOT BEEN FILLED)?. BECAUSE I HAVE A TRADING SYSTEM DESIGNED WITH ACSIL AND THE POSITIONS ARE OPEN WITH LIMIT ORDERS BUT IF IT DOESN'T GET FILLED I DON'T WANT THE LIMIT ORDER TO STAY OPEN FOR THE REST OF THE DAY, AND PROBABLY EXECUTE WHEN THE MARKET HAS CHANGED HIS INTRADAY TREND. IS THERE A WAY TO CANCELL THIS LIMIT ORDERS IF THEY ARE NOT FILLED WHEN THEY ARE SENT TO THE MARKET (OF A FEW SECONDS AFTER THAT) , OR CANCELL THE REST OF THE ORDER THAT IS ALIVE IF I'TS ONLY HAS BEEN EXECUTED PARTIALLY? THANK YOU VERY MUCH FOR YOUR HELP |
[2016-02-15 18:50:35] |
You will need to cancel the limit order when you require. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#CancelOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
