Date/Time: Sat, 28 Dec 2024 10:09:53 +0000
volume profile issues
View Count: 990
[2016-02-14 22:49:43] |
User20450 - Posts: 330 |
having some issues trying to extend the value areas , i can extend the POC but not value area and also can there be option to have value area high and value area low , so it can be plotted in the name and color ? thanks |
[2016-02-15 10:07:22] |
What Study Input did you set to do this and what is it set to? You can enable the separate lines for the Value Area High and Low. Follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#CalculatingDisplayingDevelopingPOC_VAH_VWAP Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-15 18:21:38] |
OK GOT THAT IN VP NOW THANK U , WHAT ABOUT THE TPO VAH , VAL , I DONT SEE OPTION TO DO THIS ONLY VALUE AREA EXTENSION LINE FOR BOTH
[2016-02-15 18:26:38] |
We do not understand this question: , WHAT ABOUT THE TPO VAH , VAL , I DONT SEE OPTION TO DO THIS ONLY VALUE AREA EXTENSION LINE FOR BOTH
[2016-02-15 19:39:00] |
i am asking about option to have VAh and VAL on TPO chart , i cant seem to find a way to plot them so i can name them separate as there is just 1 subgraph for both
