Date/Time: Sat, 28 Dec 2024 09:54:59 +0000
Chande Trendscore
View Count: 864
[2016-02-14 17:03:19]
User731133 - Posts: 27
Hello, I have this indicator formula that I would like to to add to my Sierra Chart studies.
Could you kindly create for me the appropriate file to be saved in the correct (ASC?) folder?
Thank you in advance kind regards
Alessandro
The formula is
If(C>=Ref(C,-11),1,-1)+If(C>=Ref(C,-12), 1,-1)+If(C>=Ref(C,-13),1,-1)+ If(C>=Ref(C,-14),1,-1)+If(C>=Ref(C,-15), 1,-1)+If(C>=Ref(C,-16),1,-1)+ If(C>=Ref(C,-17),1,-1)+If(C>=Ref(C,-18), 1,-1)+If(C>=Ref(C,-19),1,-1)+
If(C>=Ref(C,-20),1,-1)
[2016-02-15 19:17:23]
You may want to create this by using the Spreadsheet Study:
https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html
