Date/Time: Thu, 19 Sep 2024 21:52:58 +0000
semi annual charts
View Count: 1601
[2013-06-29 15:46:32] |
Paul.M - Posts: 113 |
Is is possible to construct semi annual charts with sierra ? TY |
[2013-06-29 22:50:02] |
Yes. Open a Historical chart and you can choose from the Chart menu several Daily through Yearly bar time frames.
[2013-06-30 10:43:07] |
I dont see Semi-Yearly Only Yearly or Quarterly Semi-Yearly = 6 months TY |
[2013-06-30 18:20:03] |
It is not available.
