Date/Time: Sat, 12 Sep 2026 05:37:40 +0000
[User Discussion] - ACSIL Trading offsets
View Count: 1747
[2016-02-13 23:24:08]
rhovega - Posts: 279
Looking into ACSIL documentation and examples. For any of the following (all taken from the provided tradingsystems.cpp):
NewOrder.Target1Offset = 8*sc.TickSize;
NewOrder.Stop1Offset = 8*sc.TickSize;
NewOrder.TriggeredTrailStopTriggerPriceOffset=8*sc.TickSize;
Would it work to replace "8*sc.TickSize" by "sc.ATR(sc.BaseDataIn[SC_LAST], sc.Subgraph[0], 20, MOVAVGTYPE_SIMPLE)" (or another Intermediate Study Calculation Function)?
Documentation here https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html#StopOffset would indicate that ACSIL can only use either ticks or actual price values as inputs for offsets, but not sure.
Thank you
[2016-02-14 01:13:46]
Kiwi - Posts: 375
It seems likely that it would work. Try it in sim and see what happens.
[2016-02-14 02:38:03]
EUREKA!
As reference for anyone interested, this is what I did:
On an existing trading system (from tradingsystem.cpp):
1. Defined: SCSubgraphRef ATRSubgraph = sc.Subgraph[5]
2. Calculated the ATR: sc.ATR(sc.BaseDataIn, ATRSubgraph, 20, MOVAVGTYPE_SIMPLE)
3. Got the ATR's value: float ATRAtIndex = sc.Subgraph[5].Data[sc.Index]
4. In the target/stop function, replaced "X*sc.TickSize" by "ATRAtIndex"
Thanks Kiwi
btw use the trailing stop you made a lot, awesome work!
[2017-05-09 14:06:27]
User333736 - Posts: 22
Kiwi's Trailing Stop - what is the correct way to set this up Kiwi?
