Date/Time: Fri, 27 Dec 2024 01:51:53 +0000
Multiple Volume Profiles based on Volume
View Count: 987
[2016-02-13 17:08:46]
Yoda - Posts: 106
I really like the Volume by Price study and all of the options is provides. Unfortunately, I cannot figure out how to make multiple volume profiles based on volume.
In other words, I would like SC to create a new Volume Profile every x # of contracts (i.e. 25k contacts) in the ES.
Can someone please tell me how I can do this.
Thank you,
Richard
[2016-02-13 22:13:43]
User20450 - Posts: 330
make a 25k chart and set to 1 bar on multiply profiles based on bar count
chart in pic is 5k tick chart so i set bar count to 5 so that will show u profiles every 25k ticks example
image2016-02-13_17-12.jpg / V - Attached On 2016-02-13 22:12:55 UTC - Size: 182.22 KB - 374 views
[2016-02-14 00:22:13]
Thinking about this some more, this probably is not hard for us to add. So we will try to add this in the next week.
[2016-02-29 14:51:37]
User15952 - Posts: 132
+1000
[2016-02-29 14:53:16]
thanks sierra , love it
[2016-03-07 20:46:15]
User91026 - Posts: 16
THANK YOU SC SUPPORT FOR CONSIDERING TO ADD THIS!!! many thanks.
[2016-03-07 21:37:23]
GiantAvocado - Posts: 67
Thanks for your support; I like it.
