Date/Time: Sat, 28 Dec 2024 09:35:02 +0000
status bar will not hold the position that I want
View Count: 988
[2016-02-13 15:42:27]
MMX - Posts: 119
For the longest time I've been using a vertical control bar and the green status bar was located at the bottom of the control bar, a little sliver of green, just enough to see it. I've recently switched to a horizontal control bar and now I am unable to get the "little" sliver of green at the end of the control bar, it's either the full width of the status bar (in my case that's 3 inches) or nothing (when the control bar border comes into contact with the green the green immediately drops to the lower level). Is it possible to have a little sliver of green at the end of a horizontal control bar, or is it all or nothing?
[2016-02-13 18:13:34]
Provide a screenshot of what you are seeing now so we can understand this better.
[2016-02-13 21:09:16]
MMX - Posts: 119
The 3rd screenshot is the normal location of my toolbar, the empty space within the control bar at the right border is where I want my sliver of green to be.
http://www.sierrachart.com/image.php?l=145539703423.png
http://www.sierrachart.com/image.php?l=1455397258263.png
http://www.sierrachart.com/image.php?l=1455397384770.png
[2016-02-14 00:15:14]
What you see is normal because it has to do with how the control bar items are arranged on a horizontal floating control bar.
You need to open another Control Bar, set it to only have a Status Bar, and you can size and position it as needed.
Date Time Of Last Edit: 2016-02-14 00:15:26
