Date/Time: Sat, 28 Dec 2024 09:38:14 +0000
Midpoint indicator
View Count: 4253
[2016-02-13 02:03:50]
User380978 - Posts: 25
I will like to know what indicator I could use that could give me the midpoint of a particular time, for example lets say I have 5m chart, and I will like an indicator that draw the mid point of current session, let say 9am to 230Pm et and another one for 2:31Pm until 8:59 am of next day...how can I get this done on Sierra Chart?
Thanks in advance.
[2016-02-13 09:55:22]
You can do this with the Daily OHLC study:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137
You will need to define two sets of Session Times:
http://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php
And you need to set the HL Average Study Subgraph to a visible Draw Style.
[2016-02-13 17:37:54]
Thanks, for the quick and response and your help,
I created my two session on the chart (9-2:29 pm) and (2:30-8:59 AM) ... my mid point indicator for day session works great, but I am trying to make my second mid point indicator with the "DAily OHLC" just to calculate the night session (2:30-8:59 aM) ....instead is calculating both sessions...is a way I could change this ?
Once again thanks for your help.
[2016-02-15 10:31:01]
Thinking about this, it is not possible and do what you want just by using the Daily OHLC study.
You will need to use 3 charts. Two of them need to be separately set for the two different sets of Session Times.
Add the Daily OHLC studies on those and then overlay them to the third chart. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_StudyPriceOverlayStudy.php#OverlayStudyDiffSessionTimes
Date Time Of Last Edit: 2016-02-15 10:31:37
