Date/Time: Tue, 15 Sep 2026 07:21:05 +0000
sc.GetChartBaseData((-1 * ChartNum), RemoteBaseData) not aligning arrays
View Count: 1525
[2016-02-13 00:44:41]
bjohnson777 (Brett Johnson) - Posts: 284
I'm having trouble with the arrays aligning when using sc.GetChartBaseData(). I'm testing with historical daily bars. I'm still using UNG and UGAZ for simple tests.
It looks like the correct data loads then there are a thousand or so zero's until "sc.ArraySize-1". The last number before the zero's start is the correct close for today.
For sc.GetChartBaseData(), shouldn't a negative chart number align today's daily close at array index "sc.ArraySize-1"? Debugging output correctly shows UNG as chart 2 and UGAZ as chart 3 (listed as ChartNum and CNum in the debug output).
This is the code I'm using with some debugging:
sc.GetChartBaseData((-1 * pStockIndexArray[i].ChartNumber), RemoteBaseData); //sync charts
//debug print out array.
for(index=0; index < sc.ArraySize; index++) {
  sprintf(debugstr, "data \"%s\" %d %f", pStockIndexArray[i].Symbol, index, RemoteBaseData[pInputDataIndex][index]);
  debug_PrintStringToFile(debugstr);
sprintf(debugstr, "High/Low 1: Sym=\"%s\" CNum=%d 0=%f now=%f sc.ArraySize=%d sc.Index=%d",
pStockIndexArray[i].Symbol, pStockIndexArray[i].ChartNumber, RemoteBaseData[pInputDataIndex][0],
RemoteBaseData[pInputDataIndex][sc.Index], sc.ArraySize, sc.Index);
//Find high/low code clipped for space. What matters is above this line of code.
sprintf(debugstr, "High/Low 2: Sym=\"%s\" CNum=%d high=%f low=%f PO=%f Mul=%f bars=%d
sc.ArraySize=%d sc.Index=%d", pStockIndexArray[i].Symbol, pStockIndexArray[i].ChartNumber,
high, low, pStockIndexArray[i].PriceOffset, pStockIndexArray[i].Multiplier, bars,
Here is the debug output. The "data" lines are the arrays printed out at the index number.
Node 0: Symbol="ung" Weight=1.2000 ChartNum=2 PriceOffset=0.0000 Multiplier=1.0000
Node 1: Symbol="ugaz" Weight=0.3000 ChartNum=3 PriceOffset=0.0000 Multiplier=1.0000
data "ung" 0 406.160004
data "ung" 1 404.480011
data "ung" 2 396.320007
(clipped for space)
data "ung" 2221 7.300000
data "ung" 2222 7.220000
data "ung" 2223 0.000000
data "ung" 2224 0.000000
(clipped for space)
data "ung" 3019 0.000000
High/Low 1: Sym="ung" CNum=2 0=406.160004 now=0.000000 sc.ArraySize=3020 sc.Index=3019
High/Low 2: Sym="ung" CNum=2 high=0.000000 low=0.000000 PO=0.000000 Mul=1.000000 bars=250 sc.ArraySize=3020 sc.Index=3019
data "ugaz" 0 241.800003
data "ugaz" 1 248.500000
data "ugaz" 2 254.699997
(clipped for space)
data "ugaz" 1007 1.390000
data "ugaz" 1008 1.340000
data "ugaz" 1009 0.000000
data "ugaz" 1010 0.000000
(clipped for space)
data "ugaz" 3019 0.000000
High/Low 1: Sym="ugaz" CNum=3 0=241.800003 now=0.000000 sc.ArraySize=3020 sc.Index=3019
High/Low 2: Sym="ugaz" CNum=3 high=0.000000 low=0.000000 PO=0.000000 Mul=1.000000 bars=250 sc.ArraySize=3020 sc.Index=3019
[2016-02-17 10:04:03]
You will never get an alignment and you can never expect it with this function.
Here is the relevant documentation:
Referencing Other Time Frames and Symbols When Using the ACSIL: Accessing Correct Array Indexes in Other Chart Arrays
