Date/Time: Sat, 04 May 2024 06:59:59 +0000
Show or Hide all drawings
View Count: 3744
[2016-02-12 17:45:29] |
User34124 - Posts: 271 |
In reference to the topic: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#HideDrawing Would it be possible to have an option to show/hide all drawings on the chart. If the 'copy chart drawings' feature links charts by number, then all the associated charts also show and hide appropriately. The user could then hotkey this, and it would save having a seperate, 'clean' chartbook. |
[2016-02-12 19:29:20] |
This documentation has now been updated to explain how to hide all drawings: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#HideShowChartDrawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-12 22:07:24] |
Thank you that's great. Unfortunately it doesn't seem to be compatible with the 'Copy Chart Drawings' feature. I.e. if I draw something on one chart which copies to the other specified charts, the hide function should recognise this also, and hide all connected charts? Other than that a simple option called 'hide all objects'? as opposed to just 'hide objects'? |
[2016-02-12 22:36:14] |
The Hide Chart Drawings command only affects the chart for which it is enabled.
[2016-02-13 12:27:49] |
I know this, and this is directly contradictory to the 'copy chart drawings' feature. See what I mean? If you have 5 charts linked, and hide chart drawings on an active chart, because they're linked, it makes more sense for all 5 charts' objects to be hidden. |
[2016-03-04 14:14:26] |
Can I pay you to add this feature? It would help me reduce from 9 chartbooks to 3, drastically downgrading my RAM consumption
[2016-03-05 20:54:41] |
We will get back to you about this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-03-16 17:32:36
[2016-03-06 21:49:15] |
Al SC Developer - Posts: 434 |
This is addressed in the next version. So if all drawings are hidden in the source chart, then those same drawings will also be hidden in any chart that copies those drawings.
[2016-03-06 22:35:34] |
Amazing this will rock!
[2016-03-16 11:10:41] |
Ok they weren't done in the two updates after your post correct
[2016-03-16 12:17:28] |
This is in the latest code
[2016-03-16 17:33:15] |
Make sure you are running version 1382.
[2022-04-20 17:43:54] |
HumblyTrading - Posts: 170 |
Hello Sierra chart, I am curious to know if this functionality is still enabled? Currently, when I hide drawings on a chart, they do not hide on the linked charts. Perhaps there is a setting somewhere which enables this function, but I haven’t been able to find it just yet. Any help would be appreciated! Mike |
[2024-04-11 11:36:02] |
Bump, this still does not seem to work. We can 'hide drawings from other charts' But the 'linked charts' functionality only goes one way. That is, we make a drawing, it copies to linked charts. We hide a drawing, it ignores that the drawing is linked to other charts. |
[2024-04-11 15:05:43] |
John - SC Support - Posts: 31362 |
This is still the way it works.
