Date/Time: Sat, 28 Dec 2024 09:27:22 +0000
Interactive Brokers Symbol is unknown for CSCO and GLD
View Count: 1563
[2016-02-12 16:52:50] |
Stephan908 - Posts: 46 |
Hi, I am using IB as my datafeed and I'm getting Symbol is unknown for CSCO and GLD. Other symbols are ok. Any idea how to fix this? Symbol Error - (unknown symbol with ID 100001) is unknown, unavailable, or improperly formatted. | 2016-02-12 10:47:46 Symbol Error - GLD is unknown, unavailable, or improperly formatted. The contract description specified for GLD is ambiguous. | 2016-02-12 10:47:48 I can pull them up on IB TWS just fine. Thanks. |
[2016-02-12 18:16:33] |
You need to use a more complete symbol specification which includes the exchange and currency: https://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-12 18:53:07] |
CSCO-STK or CSCO-STK-SMART didn't work but adding /[Exchange] worked but then then i can't place a trade. Thanks. Error sending order to server. | Symbol: CSCO-STK-SMART/NASDAQ | TradeAccount: | InternalOrderID: 3604 | 2016-02-12 12:47:23 * Error sending order to server. | Symbol: GLD-STK-SMART/NYSE | TradeAccount: | InternalOrderID: 3598 | 2016-02-12 12:46:00 * |
[2016-02-12 19:09:07] |
Just one of these problems with Interactive Brokers. They are a complete mess in this regard. Interactive Brokers symbology is very complicated and there are a lot of associated problems. You need to contact Interactive Brokers about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-12 19:10:52
[2016-02-12 19:26:45] |
Ok thanks.
