Date/Time: Sat, 28 Dec 2024 09:00:04 +0000
date range
View Count: 671
[2016-02-12 14:19:38] |
User24553 - Posts: 2 |
I am having problems moving the chart backwards in time. The chart can enlarged to zoom in but of you try to zoom out i.e extend the number of day's viewable the chart is not letting me go back in time more than 3 day's.I am scrolling the date control at the bottom of chart to fit more data on the chart but it is not allowing me to do so.
[2016-02-12 18:22:58] |
We assume this is an Intraday chart. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#DownloadingViewingMoreHistoricalIntradayData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
