Date/Time: Sat, 28 Dec 2024 09:53:40 +0000
Relative volume
View Count: 848
[2016-02-12 13:39:11] |
User91363 - Posts: 13 |
The Relative Volume study shows a number for Relative Volume and a different one for Cumulative Volume Ratio. For example, I trade the ESH6. It is currently showing 129 for Relative Volume and 179.4 for Cumulative Volume Ratio. What is the definition of Cumulative Volume Ratio? how does it differ from Relative Volume? Thanks, Gustavo |
[2016-02-15 10:07:55] |
We will work on clarifying the documentation for this.
