Date/Time: Sat, 28 Dec 2024 09:27:06 +0000
CFDs
View Count: 653
[2016-02-12 12:56:03] |
bretos - Posts: 1 |
Hi, i am not familliar with CFDs and need clarify some points. I am using FXCM data feed (via Your standart data service) for demo and in future planning continue with this broker in real. e. g. Dax30: If i set in SC platform quantity 1, it means that i will buy/sell 1 (FXCM) standard unit? You know the pip value? Tick increasement? I have tried to ask on FXCM support and study some of their document but little bit confusing for me... I just want be sure when i will do order in SC platform - quantity 1 - if does it mean mini, micro or lot? I know that 1 is 1, but dont know the value. Still talking about CDFs, I dont know the name of standard unit. I hope my english is understable enough to understand the point... Thanks, David |
[2016-02-12 21:49:13] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#OrderQuantities The tick size for the symbol of the chart can be found in Chart >> Chart Settings >> Tick Size for the symbol of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
