Date/Time: Sat, 28 Dec 2024 09:32:57 +0000
Numbers Bars Price at POC
View Count: 896
[2016-02-12 06:47:46]
User80177 - Posts: 29
IS there a Study or a way to get the Numbers Bars' Price at POC into a spreadsheet?
[2016-02-12 11:56:33]
This can be done by using the Volume by Price study and setting the volume profiles to 1 bar each.
The Point of Control will be outputted to the Spreadsheet.
Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php
[2016-02-12 16:23:59]
While the VBP study set to 1 bar is charting correctly, it's output to the spreadsheet is only for the most recent 10 bars. Is there a parameter that determines this limit?
Thanks.
Date Time Of Last Edit: 2016-02-12 16:36:08
[2016-02-12 18:20:55]
Check the Number of Rows Input setting for the Spreadsheet Study:
https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#NumberofRows
Also make sure the Volume by Price study is listed above the Spreadsheet study. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#StudyCalculationPrecedence
